For now I'm gonna have to go back to just one because what I'm experiencing is completely unusable. This is my first time trying multiple monitors so I'm extremely confused as to why it's acting this way & why it wont let me change or toggle between multiple desktops with alt tab or whatever key it should be. The grey bar on the HP S2031 is really annoying as well but I don't think it's damage to the monitor itself. Since if I bring up a window it just looks more like a slight grey tint & not dead pixels. I'm using Nvidia Display Driver 416.34.
Ryzen 5 1500X @ 3.9GHz On 1.3625V | MSI B350M Gaming Pro | 16GB G.Skill Ripjaws V DDR4 3200MHz | 3GB MSI GTX 1060 Gaming X 2063MHz Core 9408MHz Mem | EVGA G2 550W | 250GB Samsung 850 EVO | Windows 10 Home 64-bit Version 1903 (Build 18362.295) | MasterCase Pro 3
https://linustechtips.com/topic/991121-second-display-issues/
go to display settings. is everything looking ok there? alignment and resolution and stuff?
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/991121-second-display-issues/#findComment-11930853
I just unplugged it & went back to my single Acer V206HQL, everything looked okay though but I don't really know what I'm doing.
17 minutes ago, shmoochie said:
have you messed with the display settings? on it you can pick how the monitors are set up so its knows rez and what side of the screen for your mouse to cross over to the other screen
Nope I didn't touch any of that, I just want to be able to setup desktop 1 on my center Acer monitor to be primary & the HP for secondary desktop.
https://linustechtips.com/topic/991121-second-display-issues/#findComment-11930905
most of the time when I just plug in my monitors I always have to go mess with the settings to get them working right.
https://linustechtips.com/topic/991121-second-display-issues/#findComment-11930911
I just asked my friend & he said if I leave the HP on for a bit the grey part will go away. Although I still need to be able to change which monitor is 1 & 2 & set desktops up between the 2.
https://linustechtips.com/topic/991121-second-display-issues/#findComment-11930913
Okay I think I've figured it out but I'm wondering about something else now. I have my Acer V206HQL plugged in via DVI-D, while the HP S2031 is on a DVI-D to DisplayPort adapter cable. If I switched that around would there be anything to gain having that on my primary Acer display in gaming? I only ask because I think I remember reading somewhere that DP is faster than DVI-D.
https://linustechtips.com/topic/991121-second-display-issues/#findComment-11930958
when using an adapter I don't think it really matters. people use DP because you need DP for things like g sync/free sync to work.
https://linustechtips.com/topic/991121-second-display-issues/#findComment-11931051
