Does mocha pro work with ryzen ?
I'm planning on picking up an R7 1700/2700 on black friday,and I want to know will mocha pro work with ryzen or not,as i currently use an older locked I5 and needed to download quicktime to make the damn program work.
https://linustechtips.com/topic/990522-does-mocha-pro-work-with-ryzen/
I took this from mocha pro Recommended hardware:
Quote
Recommended Hardware:
Processor: 64-bit Intel or AMD CPU with four or more cores
Memory: 16 GB or more
Disk: High-speed disk array or SSD storage
Graphics Card: High-end NVIDIA Quadro, TITAN or GeForce Pascal, e.g. Quadro P5000 or GeForce GTX 1080 Ti
Monitor: 1920×1080 or higher, including high dpi 4k monitors
I only see your reply if you @ me.
I don't use mocha in general, but if it depends on single or dual core performence, you should get the 2700. if it can scale well, take a look into first gen treadripper (1920x and 1950x only). if you have the budget for that at least
