GPU air flow
Go to solution Solved by Skiiwee29,
Your particular card will do both. It intakes air with the fans and pushes them over the fin stack which transfers the head from the components on the card and then it dissipates it into the case.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/990486-gpu-air-flow/#findComment-11925625
Every card does both, you can take hot air out of the GPU and leave vacuum where the hot air was, fresh air will always come to compensate the pressure difference. The intent is to intake air to move the hot air out.
CPU: R7 5700X3DMotherboard: ASRock B550M-ITX A/C | Cooling: Deepcool AG400 Digital w/ Corsair ML120 Elite + 1 ML120 Elite exhaust + 2 ML140 Elite intake
RAM: 2x16GB Netac DDR4 3200MT/s | GPU: Gainward RTX 3080 Phoenix (+212MHz / +1000MHz / -6% PL)
Storage: 2TB XPG S70 Blade, Seagate Barracuda 2TB, Samsung 850 Evo 250GB (caching the HD) PSU: MSI MAG A750GL
Monitor: 2x Pichau Cepheus Fuse 28" 4k 144Hz HDR | Keyboard: Corsair K100 optical-mechanical
Headphone/headset: Kuba Disco Pro/Gamer + Beyerdynamic DT-770 Pro | OS: Windows 11 Home
Mouse: Logitech G502X + Ugreen Ergonomic MouseCase: Corsair Carbide 400C
https://linustechtips.com/topic/990486-gpu-air-flow/#findComment-11925675
https://linustechtips.com/topic/990486-gpu-air-flow/#findComment-11925676
can't think of a graphics card with fans that either push cool(er) air in or push hot(ter) air out, they always do both at the same time.
Desktop benching:
https://linustechtips.com/topic/990486-gpu-air-flow/#findComment-11925677
All GPUs have fans pushing air towards PCB. Difference comes about where air goes after that. Open-air exhaust back inside the case, in all directions. Blower exhausts out of case.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/990486-gpu-air-flow/#findComment-11928652
