If you are after airflow only then Fractal Design cases are king. Just big empty boxes with numerous fan mounting points. Define C, Mini C and Nano S are my favourites. No front drive bay mess!
I see you like the angular aesthetics more so maybe Fractal isn’t for you. I prefer the sleek look of the Fractal cases so I have a Nano S. Its just superb.
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/990435-best-airflow/#findComment-11925468
