https://linustechtips.com/topic/990341-tips-on-first-build/
Uhm, a PSU that actually has a price tag? Besides, make sure it's tier 3 or higher in the list
You'd also want modular cables, so cable management will be easier.
Desktop benching:
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11924464
4 minutes ago, Khoyez said:
Something like this maybe.
It has RX 580 8GB which has same performance as 1060 6GB, and a better power supply with an aftermarket cooler as well
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11924485
It honestly looks pretty good. Smart CPU choice as well. Personally I would check craigslist and Facebook in your area for used 1070, 1070ti, and 1080's you can get them for around 300. I personally would go cheaper on the case and grab a better motherboard. The B450 tomahawk is a good option.
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11924493
PCPartPicker part list: https://uk.pcpartpicker.com/list/mmJcV6
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  (£147.60 @ Aria PC)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£21.99 @ Ebuyer)
Motherboard: MSI - B450M PRO-VDH Micro ATX AM4 Motherboard  (£64.99 @ CCL Computers)
Memory: ADATA - XPG GAMMIX D10 16GB (2 x 8GB) DDR4-2666 Memory  (£117.10 @ More Computers)
Storage: ADATA - Ultimate SU800 256GB 2.5" Solid State Drive  (£46.86 @ Amazon UK)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£31.79 @ Aria PC)
Video Card: MSI - GeForce GTX 1080 8GB Video Card  (£449.99 @ CCL Computers)
Case: Silverstone - PS11B-W ATX Mid Tower Case  (£50.47 @ Amazon UK)
Power Supply: EVGA - 600W 80+ Certified ATX Power Supply  (£46.96 @ Scan.co.uk)
Total: £977.75
I think this build would be good as it has the good gaming performance and amazing multicore performance of ryzen paired with a brand new gtx 1080. It even has £30 left over to spend on custom cables if you're into that sort of thing.
Hope this helps.
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11924564
I would remove the cpu cooler, I would not use the armor since they have overheating issues, and 650w is overkill. Also @Khoyez, why such an expensive case?
 Use this build but keep your case if you want to
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11924573
12 hours ago, Khoyez said:
Build something like this instead....
Also, I have maintained a black-red color scheme.
CPU: AMD - Ryzen 7 1700 3GHz 8-Core Processor  ($179.89 @ OutletPC)
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  ($84.99 @ SuperBiiz)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($79.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($119.99 @ Newegg)
Storage: Samsung - 860 Evo 250GB 2.5" Solid State Drive  ($55.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($58.89 @ OutletPC)
Video Card: MSI - Radeon RX 580 8GB ARMOR MK2 OC Video Card  ($219.99 @ Newegg)
Case: DIYPC - IllusionII-BR ATX Mid Tower Case  ($49.97 @ Newegg Business)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($68.01 @ Newegg)
Total: $917.71
Generated by PCPartPicker 2018-11-03 10:07 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11925693
Total: $917.71
Drop the expensive cooler and use the stock. Also the psu is overkill for that build. The 550W version is about $30 less.
The money saved might be enough to get a stronger gpu. The Armor cards are not good anyway.
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11927170
Link the 550w psu fr $30 less...
I opted fr a 750w model coz it was on offer.
Armor cards are known fr their heat related issues, but hey, it works.
Opted fr a better cooler fr achieving better overclock.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11927619
The 750W you linked isn't $68. The Newegg link shows it as $143 when you click on it. The cheapest is $97 from Walmart.
The 550W Focus Gold semi modular is $69.90 from Amazon so just under $30 saved. Sure it is semi modular, but the fixed cables are going to be used anyway so no real difference regarding cable management.
https://www.amazon.com/dp/B077916ZZV/?tag=pcpapi-20
I wouldn't buy a gpu that is known to have heat related issues. I haven't looked at other alternatives but there might be a better option for a similar price.
The op didn't include a cooler in his spec or mention overclocking so it might not be something he wants to do. He could go with something like a Cryorig H7 though if he wanted a better cooler than the AMD one.
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11928451
The price of that psu is $103, but after rebates ND that coupon code, it's price becomes $68
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11928821
There is no mention of any rebate when you click on the Newegg link from what I can see. The coupon code says $10 off and the $25 rebate but there is no mention of that on Newegg. Doesn't it usually show the rebate on the actual website ?
https://linustechtips.com/topic/990341-tips-on-first-build/#findComment-11929058
