Samsung RAPID mode?
Solved by Sakkura,
It uses system RAM to increase performance. The actual benefit in practice is limited in most cases. As for booting, that will not be affected because the files have to be loaded from the actual SSD, the RAM starts off empty.
I would say it isn't worth it, since you lose some RAM capacity and because there's a small risk of data loss if the system loses power.
