Posted October 31, 2018 This forum is for da best pc for da best price. Link to comment https://linustechtips.com/topic/989189-best-pc-per-buck/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 31, 2018 best isn't split by brands. It's by what you need. Budget? Use case? the brand you select is up to that. You also didn't include any AIBs so what next after nvidia? EVGA? Asus? They're not in the poll. I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 11 and Fedora Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. PSU tier list How many watts do I need? PSU misconceptions, protections explained, group reg is bad Link to comment https://linustechtips.com/topic/989189-best-pc-per-buck/#findComment-11913537 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 31, 2018 Author you can also post ur gaming rig here Link to comment https://linustechtips.com/topic/989189-best-pc-per-buck/#findComment-11913553 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 31, 2018 include PC only and non gaming? Link to comment https://linustechtips.com/topic/989189-best-pc-per-buck/#findComment-11913557 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 31, 2018 Author @dgsddfgdfhgs yes Link to comment https://linustechtips.com/topic/989189-best-pc-per-buck/#findComment-11913561 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 31, 2018 Low to mid range, AMD is better. High end, Nvidia / Intel's better. CPU: i7-2600K 4751MHz 1.44V (software) --> 1.47V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 103.3MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 2133MHz 10-11-11-30 CR2, custom: 2203MHz 10-11-10-26 CR1 tRFC:230 tREFI:14000) GPU: Asus GTX 1070 Dual (Super Jetstream vbios, +70(2025-2088MHz)/+400(8.8Gbps)) SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 1 exhaust Monitor: AOC G2460PF 1080p 144Hz (150Hz max w/ DP, 121Hz max w/ HDMI) TN panel Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1 Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: HP EX920 1TB PCIe x4 M.2 SSD + Crucial MX500 1TB 2.5" SATA SSD, 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally, 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) left outside Monitor: 1080p 126Hz IPS G-sync Desktop benching: Cinebench R15 Single thread:168 Multi-thread: 833 SuperPi (v1.5 from Techpowerup, PI value output) 16K: 0.100s 1M: 8.255s 32M: 7m 45.93s Link to comment https://linustechtips.com/topic/989189-best-pc-per-buck/#findComment-11913571 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 31, 2018 @nathan32 Are you looking for suggestions on a budget PC? Rest In Peace my old signature... September 11th 2018 ~ December 26th 2018 Link to comment https://linustechtips.com/topic/989189-best-pc-per-buck/#findComment-11913802 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 31, 2018 Author yea Link to comment https://linustechtips.com/topic/989189-best-pc-per-buck/#findComment-11914899 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 31, 2018 9 hours ago, nathan32 said: yea How much do you have to spend? Rest In Peace my old signature... September 11th 2018 ~ December 26th 2018 Link to comment https://linustechtips.com/topic/989189-best-pc-per-buck/#findComment-11916891 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 31, 2018 9 hours ago, nathan32 said: yea PCPartPicker part list / Price breakdown by merchant Type Item Price CPU AMD - Ryzen 5 2600 3.4GHz 6-Core Processor $159.89 @ OutletPC Motherboard MSI - B450-A PRO ATX AM4 Motherboard $69.99 @ B&H Memory G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory $124.89 @ OutletPC Storage Samsung - 860 Evo 250GB 2.5" Solid State Drive $55.99 @ Amazon Storage Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive $58.89 @ OutletPC Video Card MSI - Radeon RX 580 8GB ARMOR OC Video Card $209.99 @ B&H Case Corsair - 200R ATX Mid Tower Case $59.99 @ Amazon Power Supply Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply $75.89 @ OutletPC Prices include shipping, taxes, rebates, and discounts Total (before mail-in rebates) $860.52 Mail-in rebates -$45.00 Total $815.52 Generated by PCPartPicker 2018-10-31 19:24 EDT-0400 Rest In Peace my old signature... September 11th 2018 ~ December 26th 2018 Link to comment https://linustechtips.com/topic/989189-best-pc-per-buck/#findComment-11916895 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
