New Build, Testing Thermals - Help!
Hi,
I just built a rig and I wasn't 200% confident I applied the thermal paste/cpu cooler perfectly, so I decided to run some stress tests.
The CPU is a 2200G with Thermal Grizzly Kryonaut and the stock cooler.
It maxes at 72C with AIDA64 and 83C with Prime95. Which number more accurately represents how high I can expect the temps to get?
Also note that the average ambient temperature of the room the PC will be in is about 10F hotter (~85F) than the room I'm testing in. (~75F)
I'm also wondering if I have to do any other special tests for the GPU part of the 2200G? Not sure if that's a stupid question.
Thanks! :)
https://linustechtips.com/topic/989108-new-build-testing-thermals-help/
Why.
What motherboard? What case?
If you're just doing gaming just run a game or something to check your temps.
I think AIDA64 will be more representative of real world temps, Prime95 really pushes the CPU with AVX loads, which you'll rarely or even never see. My 2600k OC'd taps the 80C mark in Prime95, but runs 50-70C in games, which is just fine.
CPU: R7 5700X3DMotherboard: ASRock B550M-ITX A/C | Cooling: Deepcool AG400 Digital w/ Corsair ML120 Elite + 1 ML120 Elite exhaust + 2 ML140 Elite intake
RAM: 2x16GB Netac DDR4 3200MT/s | GPU: Gainward RTX 3080 Phoenix (+212MHz / +1000MHz / -6% PL)
Storage: 2TB XPG S70 Blade, Seagate Barracuda 2TB, Samsung 850 Evo 250GB (caching the HD) PSU: MSI MAG A750GL
Monitor: 2x Pichau Cepheus Fuse 28" 4k 144Hz HDR | Keyboard: Corsair K100 optical-mechanical
Headphone/headset: Kuba Disco Pro/Gamer + Beyerdynamic DT-770 Pro | OS: Windows 11 Home
Mouse: Logitech G502X + Ugreen Ergonomic MouseCase: Corsair Carbide 400C
2 minutes ago, mgrinspan said:
It's what I had, I know it's a weird combo...
Should have saved the paste for when you put a real cooler on it lol the paste is worth more than the stock cooler.
Your motherboard has no VRM heatsink on the SoC VRM, don't run stress tests anymore unless you put a fan over the top VRM
Also only a 2 phase looks like, really should have gotten an ASrock Pro 4 or MSI Tomahawk board for the APU
This is what my fan setup looks like, the one on top and left are exhaust, the 3 (2 of them hard to see) on the front are intake. Is that enough for stress tests?
45 minutes ago, mgrinspan said:
You don't really need the extra fans for exhaust if you already have 2 fans in the front of that case, just stick one over the VRM like the image to keep it cool since it has no heatsink
Preferably you'd have some way to measure the temps of the mosfett but that's probably not needed so long as it gets direct airflow.
Any idea how I can mount a fan there that will survive being shipped 3600 miles? Without screw holes I'd expect it to fall out of anything makeshift and break something.
Probably just fix it after shipping or tell them to fix it somehow after shipping
You might be able to contact MSI or something and request to buy a heatsink for that VRM from them, it should already have the holes set up for it
Do you think all this is really necessary? Or only if I want to run stress tests? The person using the PC will likely never use it for anything intensive
Then just leave everything at stock settings and it's not going to matter
Aida is close to what intensive rendering would be like. Test using Asus RealBench if you want actual real world results. Or 3DMark and Unigine tests for more gaming style loads.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
