need an upgrade ..plzz help
Solved by GoldenLag,
buy an CX450 (2017) PSU
get an used HD 7850 as the GPU.
it will stretch the budget a bit, but just skip the CPU upgrade and get a new GPU instead,
how much Ram do you have?
denizayciceks ·
Posted in Troubleshooting5 -
3
Macaw ·
Posted in Console Gaming4 -
4
1
Shahrad ·
Posted in LTT Releases8 -
9
frozensun ·
Posted in Graphics Cards11 -
kisserik93 ·
Posted in Peripherals12
