Hi all. So need some help on deciding what cooler to get.
Currently my system contains a 240mm AIO (That cools my 7600k soon to be upgraded to 8700k) that I'm combining with a NZXT Kraken G12, as my current cooler on my 1080ti is making a racket. Therefore I'm going to need something new to cool my CPU. Ideally id get another 240mm AIO but my case can only support another 120mm AIO and they perform pretty close if not worse than some air coolers.
So if you guys could give me some suggestions for a good air cooler under 155mm in height that would be great !!
https://linustechtips.com/topic/988805-cpu-cooler-choice/
I want to recommend the Scythe Mugen 5 Rev B, but I'm afraid that's not enough for a 5GHz 8700k. I'd say you should get a 120mm AIO for the graphics card, or even one of those aftermarket air coolers like the Arctic Accelero or Raijintek Morpheus.
Desktop benching:
https://linustechtips.com/topic/988805-cpu-cooler-choice/#findComment-11909419
What case are you using? Where are you shopping / located? Budget?
https://linustechtips.com/topic/988805-cpu-cooler-choice/#findComment-11909421
I would not use anything smaller then a 240/280 on a 8700k, its simply going to be a hot chip. Is there a way you can get a bigger case since your going to be taking the motherboard out anyway?
https://linustechtips.com/topic/988805-cpu-cooler-choice/#findComment-11909423
1 minute ago, ZimBoy said:
Shopping in australia my budget is flexible within reason :) I might need to upgrade the case then. Dont think a 120 mm AIO could handle the GPU
Youd be suprised what direct die cooling is capable of. If intel or AMD figure out a way to make it so they can do direct die cooling safely and increase the die size accordingly, man that would be amazing thermals. I would suggest a 140 or 240 if you could, since it should be within a 10-20$ margin.
Case upgrade is always nice
https://linustechtips.com/topic/988805-cpu-cooler-choice/#findComment-11909432
oh man, direct die is much more risky to damage a cpu,
imagine how hard it is to seat 1kg heatsink on small die evenly. too many things may go wrong: bad paste/ contacts, greater pressure
https://linustechtips.com/topic/988805-cpu-cooler-choice/#findComment-11909443
Well there would have to be a bit of a redesign for cooling mounting for that, but it would work. But it wont happen for at least another 5 years id say
https://linustechtips.com/topic/988805-cpu-cooler-choice/#findComment-11909448
A 120mm AIO would be enough. It's exactly what hybrid cooled 1080 Ti's are and temps are generally the best compared to other air cooled solutions. https://www.gamersnexus.net/hwreviews/2957-evga-1080ti-sc2-hybrid-review-thermal-noise-analysis/page-2
GPUs are easier to cool because of the larger surface area and not direct die. I don't think direct die cooling will be used for consumer CPUs since it's risky and far from necessary.
https://linustechtips.com/topic/988805-cpu-cooler-choice/#findComment-11911452
its 100% direct die cooling and also having the larger die. If there was another thermal interface between the cooler and the die it would not cool well. And CPU risky isnt really risky if you design the PCB and Die correctly, and you can easily gain a ton of performance. Its just a big redesign, and it will eventually happen.
https://linustechtips.com/topic/988805-cpu-cooler-choice/#findComment-11912251
Without a larger die, bare die cooling doesn't make as much of a difference. Delidding gets you most of the way there while maintaining the advantages of having an IHS.
Compare the 7600k and 7900x with bare die cooling results:
https://m.hardocp.com/article/2017/02/07/7600k_naked_die_cooling_temperature_followup
https://www.tomshardware.com/reviews/core-i9-7900x-overclock-ln2,5618-4.html
The needed big redesign to minimize the risk and it still being riskier then is why I don't think it's likely. Many coolers can overtighten and potentially crack the die.
It'll probably eventually happen but no one really knows when.
https://linustechtips.com/topic/988805-cpu-cooler-choice/#findComment-11912298
Noctua NH-C14S
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
https://linustechtips.com/topic/988805-cpu-cooler-choice/#findComment-11912626
