So I have an asus dual of gtx 1060 3gb with a 1080p asus monitor 1ms flicker free 60hz and my dad is able to get an MSI OPTIX G24C 24"CURVED 24" Class , 24" Actual 1920x1080,2ms,16:9,144Hz HDMI,DP1.2 1800R CURVE it’s supposed to be wide screen anyways should I get a msi rx580 8gb it’s on eBay for $180 and the person said it was never mined or anything of those sorts thanks
https://linustechtips.com/topic/988801-problem/
I don't understand, is your dad gonna be using the new monitor thus needing a GPU? Or are you swapping out your current one?
If you're just changing monitors, no a 580 performs around the same as a 1060.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/988801-problem/#findComment-11909397
id be VERY careful of cards on ebay if you are young and not knowing what to look for. Make sure the seller is legit, has a good selling history in the past few months. Never buy from anyone who hasnt sold a single item, nor posts legit pictures instead of stuff found on the web.
1060 3gb should be able to get that done even with its downsidess,  580 8gb would offer a fair bit better performance, but for like 40$ more you could get a GTX 1070 and get a lot better performance if your PSU has enough wattage
https://linustechtips.com/topic/988801-problem/#findComment-11909410
5 minutes ago, UbeLover said:
Sorry let me clarify it’s for me and I might swap my old one out because it’s only a 3gb and the Rx 580 is an 8gb
Not much of an upgrade in terms of performance. It'll only be a very slight step up.
I recommend selling the 1060 and getting a 1070/1070ti.
Edited by bleedblue
Engrish is hard desu
https://linustechtips.com/topic/988801-problem/#findComment-11909415
11 minutes ago, UbeLover said:
Yes I am aware of the eBay sellers and their feedback and what not but the msi monitor has free sync and from what I know free sync won’t work with Nvidia cards like g sync
Still not worth it IMO.
Sell 1060 and get a Vega 56
https://linustechtips.com/topic/988801-problem/#findComment-11909442
