Having issue with SSL chain
Go to solution Solved by Sir Asvald,
I got it working. crl was pointing to the wrong IP address
Hello everyone. I'm having Issue with my SSL chain. Servers are both 2016 Standard. Freshly installed CA's. I'm testing it with https://www.ssllabs.com/ssltest/. It worked before the when intermediate CA certificate was due for a renewal. Since I've renewed it, nothing is working. CRL and OCSP status says the chain is fine..
Please help. I've attached the images
https://linustechtips.com/topic/988504-having-issue-with-ssl-chain/
Just now, beersykins said:
What steps did you go to renew it?
Did you place the renewed chain on your webserver as well?
I went to the CA console, clicked renew CA certificate..Then I went to the Root CA and updated the CRL and OCSP. As you can see from the pictures above. And I did the same for Sub CA and then reissued the webSSL certificate
Of course. I installed the Root CA certificate as well as the Intermediate.
@leadeater Can you help?
Anyone? :(
22 hours ago, Abdul201588 said:
Anyone? :(
This doesn't resolve to an IP address, crl3.learntotechsolutions.com. crl.learntotechsolutions.com does.
If that test is being done over public internet then it'll fail until you get that dns record fixed.
I added the record, I completely forgot. Thanks for that. I'm still having issues. :(
