Usually they come as single units but you can find bundles most of the time. FrozenCPU has a bunch for you to browse.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/98837-compression-fittings/#findComment-1322836
Monsoon does 6/4 packs, but most of the time buying them individually is fine.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/98837-compression-fittings/#findComment-1322954
