Can someone check to see if all these parts fit together?
I'm aiming using 25.000 DKK as a max
Already ordered a 2080TI - 10.000DKK
https://gyazo.com/6a723f7058a159085ba0408f1b575111
Aswell as that, are there any case fans that look like the ones on the list but are able to use ASRock Polychrome SYNC?
Thanks :D
https://linustechtips.com/topic/987715-build-parts-check/
I myself won't recommend the Asus AIO, it's quite expensive for an AIO that has plain fans and doesnt sync RGB lights with the motherboard. Reviews are also limited, though they do point to a typical 360mm Asetek standard performance.
only need NVMe SSD if you need a scratch disk of sort for editing work, otherwise SATA SSDs are good enough. That's the only work that rely on sustained uber high transfer rate.
Desktop benching:
https://linustechtips.com/topic/987715-build-parts-check/#findComment-11898722
personally a bigger fan of the corsair rgb pro and trident z rgb series. as pointed out by @Jurrunio, you shouldn't get a asus cooler, my recommendation would be looking into the Corsair h100i (v2), h110i and h150i pro
Or NZXT Kraken series
If you want to get an aircooler instead, coolers like the Be Quiet Dark Rock 4 pro are great too.
I like the high end boards from asus more, and think Coffee lake refresh cpu's are overpriced. but those are personal prefferences
https://linustechtips.com/topic/987715-build-parts-check/#findComment-11898733
