Not sure if this is the right place to ask stuff like this but basically my TV runs for a short while perfectly but with a small buzzing noise then you see a flicker then the display cuts out , I believe it is the backlight inverter because if I shine a torch over the screen I can see a faint image , problem is I can only see a power board , a main board and a tlc board , my TV is : bush led40127fhdcntd. , Is there anyone who could help me out , I'm fine with opening the TV as I've already done so
https://linustechtips.com/topic/987447-broken-led-tv/
I'd check the caps on the board 1st, those are typically cut rate. I've fixed several systems by replacing 25cent caps.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11896472
47 minutes ago, MrScottishGamer said:
How would I go about doing that? , I'm new to this stuff
Open the TV, look for bad caps. If you find any, de-solder them and replace with identical known good ones.
See examples here
https://www.google.com/search?newwindow=1&hl=en&authuser=0&tbm=isch&source=hp&biw=1745&bih=857&ei=1nDTW5LLHKqMggehmZG4BA&q=bad+capacitor&oq=bad+cap&gs_l=img.3.0.0l10.1001.2730..3979...0.0..0.92.482.7......2....1..gws-wiz-img.....0.ChFKCE3KlMg
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11896633
On 10/26/2018 at 8:54 PM, Radium_Angel said:
Hi I’ve had a look and can’t see anything bad with my own eyes that looks odd , maybe you might spot something I didn’t , here’s some photos , thanks for the help before btw , its well appreciated
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11915683
That board looks good. Can you get me pics of the other board?
The buzzing is not a good sign, that may be the actual power supply going bad, and the ability to fix that is over my head
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11915833
Hi , the pictures from before seem to be the power supply because that’s where the mains cable is connected , here’s some pictures of the other boards and the tv as a whole
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11916127
Well, nothing looks obviously broken, but that's the trick with electronics isn't it? No moving parts.
You can try to replace the inverter board, but I don't know how much one is in your area, nor if it's cost effective to do, but you can start there if it's cheap enough.
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11916183
I don’t believe it has a dedicated inverter board because as far as my research has gone the only boards are the power board , the board with the ports and the tlc board , I’m honestly stumped at this point lmao
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11916273
Then start with the power board. It's been my admittedly limited experience fixing TVs that it's almost always a bad power supply causing issues.
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11916714
I looked around on ebay, and the parts do exist to replace the boards, but it's gonna set you back a minimum of 50$ for the power board, and if that's not the issue, then the next board and the next and so on and it'll be close to 200$ for all the new boards and for that money, you might as well buy a new TV.
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11918068
Hiya thanks for all the help , i can find the power boards for as cheap as £18 in my the uk which is relatively cheap , might pick one up comepltley out of curiosity , I got the TV for free so I cant complain if I don't get it fixed
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11918437
Yeah free is good, and that price isn't too bad. Start with the power board, move to the inverter (if you can find one) and probably stop after that...
https://linustechtips.com/topic/987447-broken-led-tv/#findComment-11918564
