What are the difference between the boards? Spec wise, they are the same and only thing I see is the aesthetics. Is the 30 dollar difference just because of a io cover?
https://www.msi.com/Motherboard/X470-GAMING-PRO/Specification
https://www.msi.com/Motherboard/X470-GAMING-PLUS/Specification
https://linustechtips.com/topic/987275-msi-x470-pro-vs-plus/
have you checked the warranty specification?
could be that one has a longer period or more included in the warranty
Positive Mental Additude!
Just another Tired IT guy...
https://linustechtips.com/topic/987275-msi-x470-pro-vs-plus/#findComment-11895001
1 minute ago, tp95112 said:
Dont see anything about warranty on the pages
me neither, then i think they,re just aesthetic differences.
i have used the MSI site to compare and they are identical.
https://linustechtips.com/topic/987275-msi-x470-pro-vs-plus/#findComment-11895008
...one is more red than the other? kek
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/987275-msi-x470-pro-vs-plus/#findComment-11895035
