audio Audio In location?
1 hour ago, NezBoppin said:Hello,
So I want to run a 3.5mm cord from an Amazon echo dot to my PC. My idea is to be able to voice command the dot and then be able to hear Alexa's response or music played from the dot through my speakers (headphones, etc.)
Thing is, if I plug this into the blue 3.5mm jack of my onboard audio, where will the sound output?
I use Voicemeeter Banana with some virtual cables to separate audio for streaming purposes (separate audio levels for me vs. broadcast, and outputting audio through my mic on discord etc.) But before I go buying an echo dot, I'd like to know just where this input will go in my PC. If possible I'd like to get it in on one of my virtual cables.
Any help greatly appreciated!
The stereo input (blue jack) will show in Voicemeeter Banana just like any other input, you can then direct it as you please.
