so this is my first build and didn't really know much about pc gaming i learned by googling and watching videos and i have a list of components that i think work but i need someone to clarify if it will work and will be able to game at 1080p 60fps AAA titles and stream might be asking much with the cpu but idk.
CPU: AMD - Ryzen 3 1300X 3.5GHz Quad-Core Processor
CPU Cooler: Cooler Master - MasterLiquid ML120L RGB 66.7 CFM Liquid CPU Cooler
Motherboard: Asus - STRIX B350-F GAMING ATX AM4 Motherboard
Memory: Crucial - 8GB (1 x 8GB) DDR4-2400 Memory
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card
Case: Phanteks - Eclipse P300 Tempered Glass (White) ATX Mid Tower Case
Wireless Network Adapter: Asus - PCE-N15 PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fan: Corsair - SP120 57.2 CFM  120mm Fans
Other: Thermaltake TR2 S 600W 80 Plus PSU/Power Supply
Total: £702.39
https://linustechtips.com/topic/986727-first-build/
Changes:
  • Don't waste money on case fans. They're not really needed, the ones included will be fine.
  • With Ryzen you should aim for 3000mhz+ RAM, in a dual channel configuration.
    If you plan to upgrade later, you can get a single stick, but you should be aware that you will lose performance.
  • Get a better PSU. Check out the LTT PSU Tier list.
  • Try and fit an SSD in there. They're super cheap now, and day to day tasks are a night and day difference.
  • Don't get a 120mm AIO, unless your case is seriously starved for space. You're better off with an air cooler of similar price.
  • I wouldn't get the Ryzen 1300x. Try to get the 1600 at least, or if you can, something from the 2000 series. You can use the stock cooler if it helps budget wise.
  • Wait for Black Friday, cash in on the sales.
Welcome to the forum!
Don't forget to quote or tag when replying.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/986727-first-build/#findComment-11889381
Why don't you try something like this:
PCPartPicker part list: https://uk.pcpartpicker.com/list/xysY8Y
Price breakdown by merchant: https://uk.pcpartpicker.com/list/xysY8Y/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£131.94 @ Aria PC)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  (£71.99 @ CCL Computers)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  (£132.97 @ Amazon UK)
Storage: Kingston - A400 240GB 2.5" Solid State Drive  (£31.19 @ Aria PC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£35.76 @ Aria PC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  (£235.46 @ Amazon UK)
Case: Phanteks - Eclipse P300 Tempered Glass (White) ATX Mid Tower Case  (£50.99 @ AWD-IT)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£69.98 @ Scan.co.uk)
Total: £760.28
Generated by PCPartPicker 2018-10-24 20:46 BST+0100
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/986727-first-build/#findComment-11889399
than
13 minutes ago, dizmo said:
Changes:
thanks for the suggestions need to make sure i get right. i will take this and change some things on the list thanks :)
https://linustechtips.com/topic/986727-first-build/#findComment-11889426
17 minutes ago, Queen Chrysalis said:
the 1600 is loterally $129 at micro center right now, and theyll give you $30 your motherboard
Where in the UK is there a Micro Center?
https://linustechtips.com/topic/986727-first-build/#findComment-11889449
Total: £760.28
ok i have had some other options i will use both to figure out what i can get out of the lists for my budget thanks for the speedy reply
https://linustechtips.com/topic/986727-first-build/#findComment-11889514
3 hours ago, dizmo said:
Changes:
Okay I have changed the CPU to ryzen 5 1600x and 3000ghz ram and 250gb ssd  and a corsair vs 650 PSU are they good enough components to replace the other ones
https://linustechtips.com/topic/986727-first-build/#findComment-11890081
11 minutes ago, atg117 said:
There isn't one in the uk
I know. That was the point.
I think there are better options for the PSU. I'd look at the CXM line if you're on a budget.
I wouldn't get the X model, just OC the 1600.
Wait for Black Friday.
https://linustechtips.com/topic/986727-first-build/#findComment-11890090
For Ram it should be the high speed stuff since it's Ryzen and it should be in dual channel so if you don't plan to buy a another 8GB stick in the future you might as well by 2 sticks of 4GB RAM now to get dual channel mode going.
CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti
https://linustechtips.com/topic/986727-first-build/#findComment-11892260
