EVGA GTX1070 SC3 Owner , Please Help
XNet
I have issue about it's fan
1. I cannot detect how fast the fan speed ( 0 rpm on gpu z , hwid ) , only can see how much fan pwn , is it normal ?
2. when I boot the computer , only the rear fan spinning , the front fan not spinning , after GPU Temp reach 50 , Rear Fan run full speed , but PWM only show 40% , 0 fan speed , front still not working even after reach GPU Temp 71 C
3. this is new setup , fresh install windows , latest Nvidia Driver , can somebody tell me what's going on ?
Thank you
I have the same issue with my 1070 it seems to be the fans problem and not software of BIOS, as i unplugged the fan that span to 100 percent and re routed the cable so only the 2 fans spin on my 1070 strix and the problem never comes up. i'm sure its the fans issue though i'm not sure. if you're brave enough try unplug the fan that's doing this. or if its still under warranty return it to EVGA.
Hope this helps :)
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
fan power cable plug loose from the header on the card, probably.
Desktop benching:
Any idea how to fix this ? like how to disassembly without voiding the warranty ?
EVGA doesnt void your warranty even if you disassemble the card. If you're worried, give their customer service a heads up (or ask, to be polite) through email with pictures as proof
Desktop benching:
Hope this helps :)
how to do it ?
rma will take a long time
ah , thank you ! , I will contact them
Just now, XNet said:
how to do it ?
Just try dissemble the card and you should see fan connectors and unplug the one thats spinning to 100 percent. here are pictires of my card dissembled if that helps. its should be straight forward as all you need to do it remove the top shroud.
thank you , I will try
and will try to reinstall windows , I am afraid something missing
because the rear fan spin at 30% pwm since the computer start
as I know , the fan will kick in after 50c
I'm sure it's not windows as the fan does this issue when the bios screen pops up for me, its definitely a hardware issue and a replacement fan is recommended if you want this to work. they go for like 25 dollars on ebay or 15 euros. And its designed to kick in when it hits 50 degrees my GPU does that its the ECO mode. But the fan is faulty so it doesn't know whether to be off or 100 percent.
so , the real problem is the fan ?
i just wondering , is the fan controller inside the fan , or it's on the pcb board ?
its the individual fan thats the issue not the controller or the other fan would be having issues too. just buy a replacement fan for your specific card.
Thank you ,
But i am wonder , can you detecr your fan speed ?
Because i cant see it , only pwm level , fan speed : 0 rpm on my evga
Thank you ,
This may seem counter-intuitive but try rolling back to the previous driver you were using and see if issue goes away.
Then try checking to make sure the fans are not dust crusted and are clean.
If that fails -check the fan connection of the fans on the card.
Otherwise best option get fans for the heatsink:
Current computers:
Primary Computer (In Progress):
SUBJECT TO CHANGE
CASE: ROSEWIL THOR V2 Black
CPU:
Motherboard:
GPU: SAPPHIRE VEGA 56 -TBU RTX 2070 SUPER
RAM: 48 GB CORSAIR VENGEANCE LPX
PSU: SEASONIC PRIME 1300 W GOLD
STORAGE: 4x SEAGATE EXOS 4TB | Sans Digital HDD 5-Bay Rack | Sisun IDE SATA HDD Docking Station
SOUND SYSTEM: Logitech Z506 Surround Sound via Vantec USB External 7.1 Channel Audio Adapter
MOUSE: 16000DPI GAMING MOUSE
KEYBOARD: -PENDING-
MONITOR: -PENDING- AOC AGON AG241QX 24" -PENDING-
COOLING:  CPU: Noctua NH-D15 -3x NF-F12 Fan MOD || 10-12X NF-F12 || EXHAUST: 3x NA-A12x25
LAST UPDATED 4/29/20
Secondary Computer:
CPU: AMD FX-8370 Black Edition
Motherboard: ASUS M5A97 R2.0
GPU: Zotac GeForce GTX 970 AMP! Omega Core Edition
RAM: 24GB Kingston HyperX Savage 1600MHz DDR3
PSU: Antec High Current Gamer HCG-900W
STORAGE: 5x Western Digital Black 2TB - WD2003FZEX | Sans Digital HDD 5-Bay Rack | Sisun IDE SATA HDD Docking Station
MOUSE: PUREX 2400 DPI Wired Laser Gaming Mouse
KEYBOARD: DBPOWER 104 Key -3 Backlit -I KNOW! Linus doesn't approve -I have glued it to the desk and it works well for my needs.
MONITOR: ASUS VS247H-P 24 Inch
COOLING: CPU: Noctua NH-D14 -3x NF-F12 Fan MOD || 10-12X NF-F12 || EXHAUST: 3x NA-A12x25
GRAPHICS: 2x NF12s fans on graphics card + 2x NF-F12s & 1x NA-A12x25 in Fan box | 1x Vantec SP-FC70-BL Spectrum System Fan Cards
Thank you for all your help ,
Yes , yesterday I clean the fan already , and nothing work
it's still error , once it run full speed , will never slow down ( the rear fan )
and the front fan , never work , even the temp reach 85 celcius
As I do research , is it a common problem for GTX 1070 and 1080 ? I found so many people with the same problem , whatever the brand is.
So today , I sent this gpu for RMA , I can't take it no more
Hope it will go well ,
Thank you
Thank you
For the 900 series as well or so it seems.
They also seem to develop fan issues with the 400+ drivers...
From now on I am doing what he did in that video as default for all video cards I have or will own.
Current computers:
SUBJECT TO CHANGE
CPU:
Motherboard:
KEYBOARD: -PENDING-
Secondary Computer:
Thank you
Try flashing the bios to some other version of your card, it fixed mine i flashed it today and the issue is gone. Use nvflash for this, its worth a try while you still have the card. just don't use the wrong rom file haha.
