AIO placement question
Go to solution Solved by Orex,
1 hour ago, Chronified said:
Depends how long your paste has been applied for, but tbh reapplying paste isn't going to make it worse than it already is (in my experience anyways)
Hey guys thanks for your advice. I rotated the radiator around and it seems much nicer now. I did have to remove the back fan out of the way though but I don't think that will affect things too much. It was a smidghen in the way.
And the thermal paste is brand new from the block itself, I didn't reapply, just rotated, and benchmarks and idle temps are the same! So I should be good for awhile.
Thanks guys! Appreciate it!
Hi guys.
I just upgraded my AIO to the riing 360 by Thermaltake. My processor was hitting 100c on stress tests so I knew my current cooler wasn't working well if at all. Idle temps were hitting like 50c. I installed this one and now on stress tests I only hit 64c on top temp limits which is great.
However when installing the block onto the processor, the water tubes nearly weren't long enough and so the block is sideways, and there may still be some strain being placed where the tubes connect to the radiator, everything seems fine now but I wonder if that stress may cause some bending over time? I took a photo of how I have it oriented. Is there any problem with it being oriented like this? Thanks!
https://linustechtips.com/topic/986477-aio-placement-question/
The block is fine being mounted pretty much however you want, but I would be careful to not put any tension on the tubes. It’s fine if the tubes are just stiff and don’t bend well, but if you’re barely making it fit, stretching the tubes to mount the rad, then that’s different.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/986477-aio-placement-question/#findComment-11886850
Block is fine being mounted sideways. Tube tension is fine as long as they're not elastic tight and tugging on your block.
Silly question, but why not turn the radiator 180' and put the tube entry at the back of the case? Then you'd be able to have your block oriented properly.
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
https://linustechtips.com/topic/986477-aio-placement-question/#findComment-11886854
I guess because the other cooler I had also had the tubes in that direction.
Do you think that I can move the block by twisting it without having to reapply thermal paste? Probably will have to now which is a shame.
https://linustechtips.com/topic/986477-aio-placement-question/#findComment-11888833
23 minutes ago, Derrk said:
It should be fine as long as the tubes don't get any kinks in them
  Reveal hidden contents
Yeah the tubes are just full length out, they  can't kink at all. I am mostly concerned about the strain where the tubes meet the radiator as there may be some strain there particularly.
https://linustechtips.com/topic/986477-aio-placement-question/#findComment-11889024
My rig:
CPU: Ryzen 7 5800x
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
https://linustechtips.com/topic/986477-aio-placement-question/#findComment-11890234
https://linustechtips.com/topic/986477-aio-placement-question/#findComment-11890510
very nice. looks much cleaner now. In a similar situation, i had to remove a 140mm rear exhaust fan for my loop. It won't be any issue for your temps. If you notice you have negative pressure, you may just want to set your intake fan curves higher than the exhaust, or add a dust filter where your old fan used to be
https://linustechtips.com/topic/986477-aio-placement-question/#findComment-11890807
