Ive been trying to overclock my old r9 270 just to push the last bit of performance possible out of it, but as soon as i touch i apply even the slightest overclock, my clock speeds bottom out as well as my 2nd display starts stuttering. Any ideas as to what causes this ? Ive tried updating drivers and even re flashing the bios (the 1st video shows a 25 mhz overclock over the stock speeds of the Asus clock of 975, which is a 25mhz over stock amd speeds, 2nd video shows the stuttering at the same overclock
Edited by Magicpandajuice
Missing information
https://linustechtips.com/topic/986406-overclocking-r9-270-issues/
you need to run 3D load on it for the overclock to take effect.
Desktop benching:
1 hour ago, Magicpandajuice said:
I edited the post to add in some information i missed initially
that looks like unstable VRAM clock to me
Desktop benching:
Even lowering the factory overclock produces the same result,  any sort of change in clock speeds go anything, even lowering it, causes the issue
so it runs stock fine?
Desktop benching:
2 hours ago, Magicpandajuice said:
Stock runs fine, but any change in clocks causes the weird artifacts, even lowering them,
then try apps like Asus Tweak or MSI Afterburner
Desktop benching:
