hey all, so i built a pc a while back and need to connect it to a few monitors via hdmi and i plugged hdmi to the motherboard and i get no input, i notice its hard to push the cable in and i also tried vga but no input and the vga cable pushed a dint into the IO shield so i just need some suggestions on how to fix
https://linustechtips.com/topic/985770-motherboard-issues/
Which CPU do you have? Are the onboard graphics enabled in the BIOS? Which motherboard?
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/985770-motherboard-issues/#findComment-11879804
4 hours ago, LukeSavenije said:
becouse of the graphics card you don´t have output from your motherboard, or you just don´t have an internal gpu on your cpu, do you have any specs?
i have a graphics card i just wanted output via motherboard,
asrock b360 pro4, i5 8400
https://linustechtips.com/topic/985770-motherboard-issues/#findComment-11880391
