I'm about to start ordering parts this week, but I just want some input from here.
My buddy is selling me his i5, cooler, and a nice case for $115, so all in all, I'll really be spending $520
Please let me know if i should make any changes or get different parts for the build.
Also, what is some good thermal paste I should buy? I've never dealt with thermal paste, so I'd appreciate some recommendations on it :)
Thanks
https://linustechtips.com/topic/985595-new-build-help/
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($94.99 @ Newegg)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.00 @ Amazon)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($70.98 @ Newegg)
Storage: Inland - Professional 120GB 2.5" Solid State Drive  ($23.99 @ Amazon)
Video Card: Asus - Radeon RX 580 4GB Dual Video Card  ($183.99 @ Amazon)
Case: Cougar - MX340 ATX Mid Tower Case  ($44.32 @ Amazon)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($38.98 @ Newegg)
Total: $531.25
Generated by PCPartPicker 2018-10-21 16:35 EDT-0400
improvements based on what you can get new.
swap SSD and PSU out to save and invest the extra into the rx 580.
this is purely what you can get new
edit: why are you getting a B series mobo on a CPU you can overclock?
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878338
Total: $531.25
will the psu be enough in this build?
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878340
yeah. 450 watt is plenty for most builds.
if you are getting a 1080ti and 2700x/8700k you will be cutting it a bit close.
there is allways the 550 watt version of the PSU
https://pcpartpicker.com/product/FdRFf7/corsair-cx-2017-550w-80-bronze-certified-atx-power-supply-cp-9020121-na
but honestly 450 watts is fine
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878347
Just now, GoldenLag said:
also, why are you getting a B series mobo for a CPU you can overclock?
the 1200 can overclock to 3,8ghz under the stock sooler, btw
I plan to stick with the i5 7600k, could you point me in the direction of a mobo that i overclock with? I am able to spend an extra few if i have to
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878359
look at the used market for people selling Z170 or Z270 motherboards. that will be you best bet. no point spending way to much on a retail board. (overpriced as the boards are not being produced anymore)
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878363
Why are you getting a 7th gen 7600K, get an 8350K instead (if you MUST stick with Intel).
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878367
because, if you read his post, his friedn is selling him the CPU.
personally i would get a new Ryzen 1200 (yes its 1,5 years old at this point, but its still 550$ budget king)
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878378
Alright, but why should I get the 1200 over an i5 7600k?
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878386
newer plattform with CPUs for the same Mobo untill 2020.
overclockability on B series boards
pretty much the same game performance unless you spend the extra and overclock the 7600k.
btw, get the rx 580 as GPU is pretty much allways going to be the bottleneck at this budget tier
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878424
I am going to stick with the i5 7600k, I don't really plan on overclocking.
So if I get the rx580 you sent with my i5, I'll be golden and I won't run into any issues?
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878436
Yes, that will be good.
Do recommend spending the little extra on the faster Ram and saving on buying the Inland SSD
https://linustechtips.com/topic/985595-new-build-help/#findComment-11878454
