Difficulty installing AM4 CPU cooler
So I just removed my Wraith Stealth cooler as it's been making a lot of noise since I finished my build.
But I can't screw the cooler bracketsn neededfor my new cooler into the motherboard. With my PC just lying on it's side, I also can't see if there's a backplate either.
So my questions:
Is there meant to be a backplate?
Can you give be any advice/tips so I can proceed.
Cooler: Arctic Alpine 64 Plus
https://linustechtips.com/topic/985153-difficulty-installing-am4-cpu-cooler/
Which cooler are you installing? If it came with a backplate you have to install it. Take out the motherboard to do it.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
There's no backplate provided with the cooler (Alpine 64 plus).
Edit: It seems to use the cooler brackets pre installed on AM4 boards. I removed them to install my stock wraith, but now I can't seem to screw them back into moba.
Edited by Lemonpearl
It doesn't use the same mounting mechanism, it uses the am4 brackets that come on the motherboard that you had to take out to use the wraith cooler. Once you have the plastic brackets back on the motherboard you clip the new cooler onto it... there should be instructions with the cooler.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Hopefully OP has a case that wouldn't require that.
Primary PC:
PSU tier list
How many watts do I need?
Right, but I can't seem to screw the plastic brackets onto the motherboard. Is there supposed to be a mounting plate?
Quote
IMPROVED INSTALLATION: The mounting of the Alpine 64 PLUS is absolutely transport proof, the MX-4 thermal compound already pre-applied onto the heatsink. New in Rev. 1.1: The installation is significantly easier and even quicker - Put it on (clips hook in automatically), fasten the screws - ready
Yes there was a backplate that came on the motherboard that you took off, hopefully you can find where you put it.
Sorry I misunderstood... if you just removed the wraith cooler the backplate most likely dropped which is why you can't screw the new cooler in.... you should remove the motherboard from the case to install the new cooler properly.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Okay. I'll do that. Also, when cleaning then CPU, do I need to remove it from moba?
Not if you're careful not to spill the alcohol on the board... it won't harm it as such, but you will have to wait for the alcohol to disipate (dry out) if you do spill.
Personally I remove the CPU and give it a good clean with a microfibre cloth, I have loads of them and just wash them afterwards. I make sure to have a firm grip on the CPU and I make sure the pins are protected. If you're worried about dropping it or something see if you can clean the CPU while it's still in situ, clean off what you can by cleaning multiple times. When it looks clean you can then apply the new thermal compound, or if your cooler comes with pre-applied TIM, you can just go ahead and install the cooler.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Thanks. Annoyingly, a drop of thermal compound remover fell onto the board. It's tiny and I've dabbed it off but I can still see where it landed. How long should I wait for it to dry?
It depedns on what exactly you used as remover? if it's isopropyl alcohol it will dissipate almost immediately.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
3 minutes ago, Lemonpearl said:
which one did you spill?
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Ahh OK, in that case, use a couple drops of the "cleanser" on a cloth and gently wipe the spill away.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Just now, Lemonpearl said:
By "cleanser" do you mean the "purifier"?
yep
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
1 hour ago, paddy-stone said:
yep
Clearly there's something wrong with my arcticlean. I've been as careful as possible and I've spilt more drips. This time it landed on the pcie header.
What to do now? Would it be better to just get a new board at this point?
I spilt a couple drops of the "thermal material remover" http://www.arcticsilver.com/arcticlean.htm
One drop unfortunately landed on the metal rim of the PCIE port. I'm not sure if any got inside, but it's a possibility.
So far, I've dabbed both of the landing spots with (non-lint) paper towels. But I can still see a mark.
Someone also suggested using the ArtiClean "thermal surface purifier" to clean the board. Would that be a good idea?
That stuff flashes away pretty quick so after a few mins there shouldn't be anything left, you'll be fine as is.
12 minutes ago, Lemonpearl said:
Embarrassing, but I messed up yet again and lifted my cooler up getting a thin line of thermal paste on the cpu.
Should I clean it off or nah?
def clean it off first.
PC: CPU: Ryzen 5 5600X @ Curve optimzer -25,  Cooler: Noctua NH-D15 Chromax.Black, Motherboard: Asus Rog Strix B500-F Gaming WiFi II, GPU: Sapphire Nitro+ RX 7800XT @ Stock , RAM: G.Skill Trident Z RGB 2x16GB DDR4 3600Mhz CL18, HDD: Western Digital Caviar Black 2TB, SSD: Samsung 850 Evo 250GB | Team Group MP33 1TB NVME, Case: NZXT H7 Flow Black, PSU: NZXT C1200  I Peripherals: Keyboard: Ducky Shine 6 RGB Special Edition, Mouse: Razer Orochi V2, Headset: Philips SHP9500, Mousepad: Glorious Stealth Extended I Laptop: MSI GS63VR Stealth Pro CPU: i7-6700HQ@ 2.6ghz, GPU: GTX 1060, Memory: 16GB DDR4 2400Mhz, HDD: 1TB+128GB SSD
