What does s Network switch do?
Go to solution Solved by Donut417,
4 minutes ago, MojangYang said:
Okay, I know this question sound like a noob question, that is because it is.
Some websites told me a switch connect many devices to the same network, and the switch is connected to the router. But why do people need switches, I mean why can’t they just connect directly to the router? Is the switch just a Ethernet splitter?
Im going to blow your mind. Many routers have switches build in. Mind blown? Ethernet is not like electrical cables, you cant just split it with a spliter. You have to use a Hub or Switch. Hubs are no longer used any more because of limitations they had. Switches allow you to connect multiple Ethernet devices together. For example you have maybe 4 Ethernet devices in your bed room, but your router is in the living room. Are you going to run 4 Ethernet cords, or you can run one to a switch and connect all the devices to a switch. Another reason to use a Switch is if all the ports on your router get filled.
https://linustechtips.com/topic/984957-what-does-s-network-switch-do/
8 minutes ago, danomicar said:
.... Your average home network won't have need for a switch
only if only 2 devices
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
Most routers have at LEAST four ports.
Most businesses even aggregate all of their users in the switch side.  As above a home router is more often than not a combo device of a router, a switch and a wireless access point.
For simplicity's sake most people are just told stuff like 'plug it into the router bro'
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
Because they have an built in switch. Just because it is built in doesn't mean it's not required.
