WiFi Card
Solved by flibberdipper,
There's nothing wrong with it, and all things considered it's not a bad card. I'm personally a fan of these bad lads because the antenna is fantastic (same signal strength as the annoying ones that stick out but you can move it wherever) and if you feel the need to upgrade the chip along the way, you totally can. And being able to have an internal USB port (if you plug in the "extension") can be kinda handy.
