Need recommendation.
Solved by Max225719,
I have the Acer XR382CQK it's a LG IPS panel 38" curved running at 3860x1600 75Hz display. It's also the same panel that's in a Dell and a LG monitor but only the Acer is factory overclocked to 75Hz. The screen is beautiful, I greatly enjoy gaming on her and I came from a Samsung quantum dot so that's saying something.
Granted it's a higher resolution then you are looking for and not a gsync however it looked way better side by side compared to the x34 and nearly every other high end ultra wide. If you live near a microcenter (it's where I went to compare) you can pretty much see them all side by side
