Hello,
I was playing Hoi4 yesterday and the game was tanking and lagging all over the place, this morning I checked my device manager as after I restarted it this morning the problems hadn't disappeared.
Thereby I discovered that both my Intel and Nvidia graphics were reporting an Error code 43, so I googled how to solve this, I reinstalled the graphics drivers, this fixed my Intel integrated graphics, however even after clearing and reinstalling my Nvidia card with DDU, It still reports the error code.
Any help is appreciated :)
Thanks
Specs:
Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz 2.40GHZ
8.00GB Ram
Integrated Intel® HD Graphics 4400
NVIDIA GeForce GT 740M
64Bit
asus laptop S551L
https://www.goodgearguide.com.au/review/asus/vivobook_s551lb-cj081h/531481/specs/
https://linustechtips.com/topic/984404-help-error-43-on-nvidia-gpu-cant-fix/
1 minute ago, TomShaw said:
How would I do that?
First backup files, then follow instructions here:
https://support.microsoft.com/en-us/help/4026528/windows-reset-or-reinstall-windows-10
Make sure you click "keep files"
it's time
Thanks, restoring my computer is kind of my last resort. I am wondering if there is a way to tell if my GPU is having a hardware failure before I restore it.
20 hours ago, bigmouthbob1 said:
23 hours ago, RollTime said:
No. It will keep your files but reinstall the OS itself. You won't be resetting everything.
Thanks for the help.
My computer froze when switching from word to excel and after the forced restart chrome was running smoothly, I checked device manager and now it's working,
soooo FML
soooo FML
Well... problem solved, I guess.
it's time
