Newly built PC won't display anything with GPU installed
Axtar
First, I finished the build, and turned it on. The PC starts and all CPU, GPU fans spin and HDD LED lights up as usual, but nothing on the screen. Noticed that the fans aren't spinning as loud/fast as they do when successfully boots up. My monitor (Alienware 25" 240hz) and all the cables (HDMI) are working. Then I tried turning on the new build without the GPU and it boots up normally and works fine. By the way, I'm always using HDMI ports on both the mobo and the GPU. All the parts showed up like CPU, RAMs and SSD. I took the GPU out and tested it on my working build (with EVGA 450W 80+ Bronze (Brand new)) and it worked just fine. So I thought the GPU didn't like the PSU (used SFX 450W 80+ Bronze). Swapped the PSUs, still no success. Took apart the build and started from the scratch again. Still the same. Cleared the CMOS, no success and got the reboot and select proper boot device screen. Tried repairing it using windows 10 usb drive. No success. I didn't wanna spend more time on fixing the OS since I didn't have anything on it, so I just reinstalled windows 10 anew. This is where I stopped last night. I am reading some forums and kind of have a lead on the fix. Someone suggested that I upgrade the BIOS, because, apparently the BIOS can change the video output either via onboard GPU or external GPU. So I'm planning on upgrading the BIOS tonight: https://hardforum.com/threads/how-to-update-bios-foxconn-motherboard-h67s-lga-1155.1661637/. However, before spending more time on this, does anyone have quicker solution or more basic troubleshooting?
i5-2400 3.1GHz (Used)
8GB (2 x 4GB) DDR3 RAM (OEM for Dell) (Used)
ASRock RX570 4GB OC (Brand new)
Kingston A400 240GB SSD (Brand new)
Foxconn ITX Mobo (New other)
Edited by Axtar
Just to be certain - when you're using the HDMI connected to the GPU, you should have the correct HDMI plug selected for display on the monitor (If you're using multiples).
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
Have you set the PCIe as default as opposed to iGPU in BIOS?
Quote
CPU-AMD Ryzen 9 5900X / CPU Cooler-Noctua NH-D15S / Motherboard-MSI MPG X570S CARBON MAX WIFI / Memory-G.Skill Trident Z Neo 64 GB (4 x 16 GB) DDR4-3600 CL16 / Storage-WD WDBSLA0040HNC-NRSN 4TB 3.5" 7200 RPM / Storage-WD Red 6 TB 3.5" 5400 RPM--Crucial P3 4TB 3.0X4 NVME--Sabrent Rocket 4.0 1TB 4.0X4 NVME--Corsair MP600 CORE 2TB 4.0X4 NVME / Video Card-XFX Radeon RX 6900 XT / Case-Lian Li O11 Air Mini / PSU-SeaSonic PRIME 1000 W 80+ Gold / Sound Card-Creative Labs Sound Blaster Z w/Shield / Monitor-BenQ GW2765HT 27.0" 2560 x 1440 60 Hz / Monitor-Asus ROG Strix XG27AQ 27.0" 2560 x 1440 170 Hz / Keyboard-Logitech G Pro / Mouse-Logitech G502 LIGHTSPEED Wireless / UPS-CyberPower GX1325U / Fan Controller-Corsair Commander Pro
Quote
CPU-AMD Ryzen 7 5800X / CPU Cooler-Corsair iCUE H100i ELITE CAPELLIX / Motherboard-Asus TUF GAMING X570-PRO (WI-FI) / MemoryG.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL16 / Storage-Western Digital Black SN750 SE 1TB 4.0X4 NVME--Samsung 970 Evo Plus 2TB 3.0X4 NVME--Seagate Barracuda Compute 3 TB 3.5" 5400 RPM / Video Card-Asus KO Gaming OC GeForce RTX 3070 / Case-Lian Li O11 Air Mini / Case-LIAN LI PCI-E 16 X 4.0 Black Riser / PSU-EVGA SuperNOVA 850 G+ Gold / Monitor-LG 22BK430H-B 21.5" 1920 x 1080 60 Hz / Monitor-MSI Optix 271CQP 27.0" 2560 x 1440 165 Hz Curved / Keyboard-Logitech G413 TKL SE / Mouse-Logitech G502 HERO Wired / UPS-CyberPower CP1350PFCLCD / Fan Controller-Corsair  Commander Pro / Sony HT-S200F Soundbar
Quote
CPU-AMD Ryzen 7 5700X / CPU Cooler-Scythe Mugen 5 Black Edition / Motherboard-MSI MPG B550I GAMING EDGE MAX WIFI / Memory-G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 / Storage-Samsung 970 Evo Plus 1TB 3.0X4 NVME--PNY CS900 1TB 2.5" SSD--Samsung 970 Evo Plus 2TB NVME/ Video Card-EVGA XC GAMING GeForce RTX 3060 / Case-Cooler NR200P / PSU-Cooler Master V750 SFX GOLD / Keyboard-HyperX Alloy Origins Core / Mouse-Logitech G502 HERO Wired / UPS-CyberPower LE1000DG-FC / Fan Controller-NZXT RGB & Fan Controller
Quote
CPU-AMD Ryzen 7 5700G / CPU Cooler-Scythe Shuriken 2 / Motherboard-Gigabyte X570 I AORUS PRO WIFI / Memory-Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3800 CL18 / Storage-WD Blue 1TB 2.5" SSD--Samsung 970 Evo Plus 1TB 3.0X4 NVME--Patriot P310 1.92TB 3.0X4 NVME / Case-InWin B1 Mesh / Keyboard-Logitech K380 / Mouse-Logitech G502 LIGHTSPEED Wireless / Monitor-ViewSonic VX1755 17" 1080p Portable IPS Gaming Monitor 144Hz / Speakers-Creative Muvo Go (Black)
I haven't tried that yet. That'll be first on my to do list tonight.
Sorry I meant power cable and HDMI cable by "all cables". There is only one HDMI plugged to my monitor and it detects any signal automatically which works on my main gaming rig.
Is that option available on all BIOS? It's kind of an older mobo.
Not sure, check this out.
It is set up for PCIe
Quote
Quote
Quote
Quote
Thanks so much. I'll definitely check it out tonight.
Just don't mistake PCI for PCIE :P
PCIE is the one you want. (It may be labeled PCIX or various alternatives)
As long as it doesn't boot from the igpu option :P
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
I tried changing the settings to both PCI/IGD and PCI/PEG. Neither of them fixed the issue. By the way, when gpu is installed, it turns on but after about 15 seconds it turns off on its own and turns back on again and stays that way.
You want PEG.
PCIE Express Graphics. (PEG)
As Primary. This is your dedicated GPU.
So you'd want PEG/IGD if it's listed.
Or PEG by itself to remove the iGPU from being loaded too.
Plug display cables in dedicated PEG to your monitor. Should be good to go.
Stupid Motherboard makers changing it from PCIE TO PEG.
8 hours ago, SkilledRebuilds said:
You want PEG.
After trying many different things it went back to the reboot and select proper boot device screen so I reinstalled the OS and tried putting EVGA GTX 1060 3gb and it works right away. I concluded that it was a compatibility issue. I might try to change the BIOS settings to PEG/PCI one last time. You don't want PEG/IGD right? Because IGD is Integrated Graphics Device or whatever. But yeah, I have spent far too much time on this trying to figure it out. My wife and kids are already upset about not spending time with them as much so if it doesn't get fixed I'll just keep the GTX 1060 in there and RX 570 in my main rig, my 240hz monitor is freesync anyway so it could be actually a better turnout for me. Thanks for your inputs guys. I'll let you know after I try PEG setting.
I did say to put PEG/IGD.....figuring you'd want both. Much of a muchness.
PEG/PCI or PEG only should suffice just fine for only the dedicated GPU.
