Hello,
I am trying to make a gaming PC built inside of an old 1979 Millennium Falcon toy, I was looking at different cooling solutions due to the lack of space and limited air flow. It's possible to run a normal PC in it but I want to be able to do some gaming on low spec hardware (No overclocking) I was looking at water cooling as a good solution but the rads are too big for the case and I don't thing that it will get enough airflow from normal fans for the PC not to run too hot. I have attached a picture of the back as this is where I am planning to add the fans.
Thanks for any advice in advance.
https://linustechtips.com/topic/983323-help-with-cooling/
I'd probably go with the new Athlon APU w/ vega APU, or a R3 2200G. It'll probably be decently easy to run thermal-wise.
I'd probably get an Engine 27 or a Zalman CNPS2X (I have one of these cooling an old Haswell i5 office PC and it's silent), and cram as many 40/60/80mm (whichever fit) case fans inside the case as possible.
Though I don't know where you'd put a PSU, unless you get a board that supports external PSUs, which only ASRock makes for intel.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/983323-help-with-cooling/#findComment-11857424
