I was wondering if Dominator would fit in the case I have picked out. Sooo..... Yeah.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($149.99 @ TigerDirect)
Motherboard:  Asus SABERTOOTH 990FX R2.0 ATX AM3+ Motherboard  ($174.99 @ Newegg)
Memory:  Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($87.32 @ NCIX US)
Storage:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Amazon)
Video Card:  Asus GeForce GTX 760 2GB Video Card  ($249.99 @ NCIX US)
Case:  Corsair Carbide Series 300R Windowed ATX Mid Tower Case  ($89.99 @ TigerDirect)
Power Supply:  Corsair Enthusiast 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($109.99 @ NCIX US)
Optical Drive:  Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($26.97 @ Newegg)
Operating System:  Microsoft Windows 8 (OEM) (64-bit)  ($99.99 @ Amazon)
Total: $1109.21
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-05 21:21 EST-0500)
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/98322-will-it-fit/
Would help if you said what case it was.
CPU: FX-6300 @ 4.4 ghz GPU: MSI 7950 Motherboard: Asrock 970 Extreme R2  RAM: Teamgroup Elite Black 8GB 1600mhz
Case: Corsair 300r Windowed Storage: 60GB Corsair SSD boot, 1TB WD Black storage PSU: Corsair GS600 Displays: AOC 22", Acer 24" both 1920x1080 60hz
Cooling: Coolermaster V8 cpu cooler Keyboard: QPAD MK50 Cherry MX Blue Mouse: Logitech G500s  Mouse Pad: Corsair MM400 Sound: Sennheiser G4ME ONE headset, Audio Technica ATH M50s
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315553
If it fits it ships
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315561
Really? You have over 2k posts and you can't give us the info we need?
It's kind of hard to answer a question when you give us no information to go off of.
Whoops. Phantom paste inbound!!! I updated it. Sorry. :P
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315580
I figured it out mate, looked at the 'dominator' rig in your sig.
Short answer - everything will fit fine. Do you have plans for water cooling at all?
MAXIMUS VII HERO | i7 4770K w/ H100i | 2x8GB 1600MHz | GALAX GTX 970 x2
250GB SSD boot | 250GB x2, 1TB SSD storage | Corsair 400C | Corsair RM550
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315589
It is in his signature, so you could have looked there. Still, he should have posted it in his original post anyways.
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315599
What case?
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315613
I don't know yet. If I do, it will be an H100i.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315639
What case?
The Corsair Carbide 300R.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315641
300r
System: 5930K, MSI X99 SLI PLUS, GTX 780Ti (SLI),  840 EVO, Fractal R4 (Full Custom Loop)  (IP)
Media Server/Perm Folder: i3 4130, CX500, 4 X WD Red 1TB, 60GB Adata SSD for boot, Node 304, ASrock Z87-E ITX, 8GB Kingston Value Ram
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315646
Everything fits just fine.
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315654
You can fit three of those beasts in the 300R, so you should be right
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1315680
I was more worried about the motherboard, but everyone says it'll be fine. :D Can't wait to get money for this thing.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/98322-will-it-fit/#findComment-1316343
