CoolMaster RGB fans
Solved by W-L,
7 minutes ago, SugarTe said:Ok, So I basically just throw away the controller that came with it and instead just buy a 1 to 4 RGB splitter?
For Aura sync it doesn't require the controller, the controller as said is designed for systems without integrate RGB headers or if you want to interdependently use coolermaster's software control option.
Yes an RGB splitter will be what you need just take note of how many fans or LED strips you're adding to not overload the header.
