Graphics card PCI wire problem...
Hello guys,
Please bare with me on this short message. I know it sounds confusing so I attached some pictures to help out!
Right so I've just recently bought a gtx 1070 which has a PCI port for 8 pins. My old graphics card was a windforce gtx 760 which had a 14 pin port. The PCI cable I was using had a 6 + 8 connector which made 14 pin holes, but it only had 11 wires attached, 5 wires on the 6 hole connector and 6 on the 8 hole connector. First question, was that fine? (See pictures below)
Second question can I take 2 wires from the 6 pin connector and add them to the other 6 pin connector with 2 spare holes and make it an 8 pin connector?
Doing some googling I found that the red wire is 5v, yellow is 12v and black is ground.
Third question, when I Google 8 pin connectors they all have different ammounts of yellow, red and black wires. E.g some have 4 yellows and 4 black or some have 3 yellows and 5 blacks and it's really throwing me off, I don't know what to do?
Any help would be greatfully appreciated! Sorry if this sounds like a stupid thing to ask and thank you kindly in advance for any help!
https://linustechtips.com/topic/981559-graphics-card-pci-wire-problem/
First things first, you don't just need 8 pin, you need 8 pin PCI express. The CPU also does 8 pins but they're completely different.
Second, you shouldn't use molex converters. You should upgrade to a power supply that can actually deliver the correct power required.
Primary PC:
PSU tier list
How many watts do I need?
1 minute ago, Jonj99 said:
Okay thanks, I'll upgrade my PSU. It was a Corsair CX500M. I didn't realise technology has updated and they're old school now. Know of any decent PSU's? I'm not on a budget but 500w is enough to power my system
The cx500m is absolutely modern enough, did you lose the cables? It should include PCIe cables with enough pins for a 1070, and you can probably get replacements from Corsair.
Primary PC:
PSU tier list
I must of lost the cables, I've moved house a few times since I built my PC 3 ish years ago. All I have is an 8 pin with 6 pins and a 6 pin with 5 pins. If this PSU is fine then I'll just buy an 8 pin PCI express on Amazon like you said
Yeah you should Google "Corsair cx500m PCI Express power cables" to see if you can get them
Primary PC:
PSU tier list
I hate when people are like - JUST THROW IT OUT AND BUY SOMETHING BETTER.
Man, I have a box of cables...weighs like 50 lbs...personally Id rather TROUBLESHOOT a problem than to just spend more money on it.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
