Need help for upcoming pc build
Xyrock
Hi! im gonna get a new pc soon as blackfriday hits.
Currently looking at the rtx 2070 which comes soon
-amd ryzen threadripper 1920x for rendering / video making
-32gigs o ram
-compatible motherboard.
 Other components i can probably get without help, what motherboard supports the newest cards and is there difference on what ddr4 ram to get?
also for future builds, how do i see which motherboards are compatible to which cpu's and rams?
The website of every manufactur should say whats compatible and whats not. pcpartpicker.com is also really good ad it.
speed and cash latency of the ram depends on your budget and if you care about looks. If you care about i would say Corsair and G.Skill are making good ram with a high speed.
GPUs are supportet on nearly any Mobo i have a 1080 with an i7 4790 (non k)
and yeah every x399 Mobo should work it depends on what connections do you want
i see... thank you for your info, where can i find which motherboards are x399?
Go to Pcpartpicker. Start a new system select the 1920x on "CPU", and if you are going to chose a Mobo its automatically sorted
seems like pcpartpicker is a dream site for builders xD thanks!
yeah it is really great
