I bought an HP Omen 15 dc0051nr a couple of months ago, it was a bit loud during regular use so I decided to download Intel Xtu and reduce the voltage by 0.160 v. After this the temps went down drastically but the sound from the fans at idle were still quite annoying, I decided to go into the bios and turn off: fan always on. This setting allowes the fan to shut off completely if the cpu or gpu is under 50c.
Now my question: Is 45-50c a healthy idle temperature for an i7-8750h + gtx 1060?
Thank you for your time.
https://linustechtips.com/topic/980800-cpu-temps-healthy/
Normal temps for idling are around 35c. What are your temps during use?
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/980800-cpu-temps-healthy/#findComment-11834476
Those temps are fine.
https://linustechtips.com/topic/980800-cpu-temps-healthy/#findComment-11834701
2 hours ago, D148xZ said:
When browsing my temps are around 50c, with gta V it goes up to 60-70c.
Oh, well those temps are good
https://linustechtips.com/topic/980800-cpu-temps-healthy/#findComment-11834935
