tl-wdn4800
Nice profile picture--I remember actually trying to play with that card before simply because it looked good.
https://linustechtips.com/topic/98056-wifi-cards-question/#findComment-1311542
If your motherboard has a Mini PCIe slot, you can get one of the better Intel WiFI cards. If your motherboard does not, a 3x3 PCIe 1x card like the ASUS PCE-AC68U
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/98056-wifi-cards-question/#findComment-1311550
My motherboard is an Asus Z77 Sabertooth.
Then it does not have an integrated mPCIe slot. you can either get a normal PCIe 1x solution like the Asus PCE-AC68U, or a Intel Centrino 6205 Desktop kit.. You can also go along the USB route.
Personal Rig
https://linustechtips.com/topic/98056-wifi-cards-question/#findComment-1312571
Would this card be any good "ASUS PCE-AC68 Dual-band Wireless-AC1900 Adapter IEEE 802.11ac, IEEE 802.11a/b/g/n PCI Express Up to 600 and 1300Mbps Wireless Data Rates WPA2"?
https://linustechtips.com/topic/98056-wifi-cards-question/#findComment-1312730
It is the best on the market, especially if you have an AC router.
Personal Rig
https://linustechtips.com/topic/98056-wifi-cards-question/#findComment-1312769
