Look up your motherboard site. There might be some utility software that will do that for you.
https://linustechtips.com/topic/98050-driver-help/#findComment-1311469
Yea i've got a Gigabyte GA-Z87-HD3 but when i try using the Download Centre Tool it says "Please wait for Download DL-Program", Think it might be an error with there site ot something because i've waited 10 minutes lol xD
https://linustechtips.com/topic/98050-driver-help/#findComment-1311477
I've had that issue before with Msi's utility. It doesn't work sometime--not exactly sure why though. You could always just download drivers manually.
https://linustechtips.com/topic/98050-driver-help/#findComment-1311482
Bookmark site where downloads are located. I wouldn't recommend using any 3rd party driver updaters. They will most likely install invalid versions or older than what are available.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/98050-driver-help/#findComment-1311927
