Case Fans for Asus Z370-E
Hisada
HI i just want to check am i right on plugging my fans? cause im new at building PC so i need to know whats the mistake here. hope you guys can help me.
https://imgur.com/a/tLomMnz
Yeah. Looks alright.
so there's no issue rite? even if i OC it wont affect anything? cause im just worried it will fry my MOBO.
No. Why? Also, why would you need that many fans?
really thats many? haha i thought that was normal. is 3 case fans enough?
I have 2 intake and 1 exhaust and 1 on the cooler. I found that anything above that does not make a significant difference in most m-atx cases.
so 3 is enough then. 2 front 1 at back. then i just stick to nzxt aer for my fractal meshify case. i didnt know that i thought the more fan the better as it keeps your PC cool.
