Hello guys, i have a problem. Today i wanted to clean my pc from dust.  No problems until then. So , i take off all the parts , i just blow them and then i put them back. When i start my pc, 5 beeps and restart. Something wrong with my ram slot. When i have both rams beeps, when i put one ram in slot1 pc starts , when i put same ram in slot2 beeps . Same again with other ram stick. So my rams are okey. Something wrong with slot2 . I restore bios, i update bios , i play with ram slot voltage , i try to clean slot better, i check my cpu fan twice but no result.
What do you think? I destroy slot? Can you suggest me something?
i3 6100 , gigabyte ga h110 s2h , ddr4 2x4 2133 hyperx fury .
(Sorry for my english)
https://linustechtips.com/topic/979297-ram-slot-problem-i-think/
Don't apologize for a language you are not fluent or native to =]
Did you open the RAM slots when you removed them or did you just FORCE them out? RAM can only be inserted one way so I will assume you didn't jam it back in.
RAM slots usually go slot 1 and slot 3 OR slot 2 and slot 4. Check if your motherboard requires slot 1 and 3 or slot 2 and 4.
That board only has two RAM slots.
I didn't check it, but that's good info to know.
So to OP, did you force them out/in or did you pull the tabs open and gently yet firmly removed them/put them in place.
Maybe you bent some of pins?
My mobo has 2 slots. Yes i open ram slots before i force them out.    Im sure i did all steps correct. I know from pc building. But i didnt exept that. You think must be destroyed?
Im sure i did it correct.  Tabs "clicks" when i put the ram in slot. I didnt force them
