Is there a good software that will allow you to create custom fan curves. On my computer I just installed a new cooler and the fans are unnecessairaly loud. (I have checked the temps) I have an asrock extreeme 3 motherboard and i'm able to manually change the fan speed using this program, but I'm not sure if it can do can curves like on some graphics cards overclocking software.
I want something with a simple interface where I can drag a line up or down.
This is my opinion, it doesn't mean I'm right and is liable to change at any time. I may offend of which I apologize in advance.
(Our lord and savior: GabeN)
https://linustechtips.com/topic/97899-fan-speed-control/
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/97899-fan-speed-control/#findComment-1309667
