I have a tomahawk b350 with a 1600x that has been preforming fine since i got it. Today after setting up a vm i forgot to enable virtualization in the bios. Now i when i reboot i cant get into bios. If i spam del then the screen just black screens. If i restart and don't spam del then i get into my computer as normal and everything is fine, overclocks are saved etc.
CPU:R9 3900x@4.5Ghz RAM:Vengeance Pro LPX @ 3200mhz MOBO:MSI Tomohawk B350 GPU:PNY GTX 1080 XLR8
DRIVES:500GB Samsung 970 Pro + Patriot Blast 480GB x2 + 12tb RAID10 NAS
MONITORS:Pixio PX329 32inch 1440p 165hz, LG 34UM68-p 1080p 75hz
https://linustechtips.com/topic/978915-msi-tomohawk-b350-issue/
3 hours ago, Brooksie359 said:
www.laptopmag.com/articles/access-bios-windows-10 this might help. Otherwise you can always try resetting the cmos.
Doubt you fully read the thread.
Anyways problem was fixed by using a different monitor
https://linustechtips.com/topic/978915-msi-tomohawk-b350-issue/#findComment-11818062
Hey that's how I got into my bios when it wasn't letting me do it on startup for some odd reason. Also resetting the cmos should have fixed the issue based on what you desrkbed because it seems like a bios setting issue and resetting it would set the bios back to default.
https://linustechtips.com/topic/978915-msi-tomohawk-b350-issue/#findComment-11818676
