 Hello there, how ya all doing?
 I was wpndering if anyone could confirm a hypothesis I have over a conundrum involving a very warm devil...
 See, about 3 years back, I bought a bundle with an ASUS Maximus VII Ranger and an i7 4790k.
 All well and good, but after setupI decided to run the usual tests, set my bclock to 100, static mults to 40x and disabled all auto voltage and freq controls like speedstep etc.
 I ran AIDA and Prime95 Blend tests, and holy crap I'm throttling at 99c...
 I figured that it was the crappy stock cooler, and so promptly went out and got me a Corsair h100i gtx, some coolermaster grease and set to work.
 Lo and beholed, thermals went from 66c idle to.
.. 50c.
 Ok, not quite fresh, but workable. Still, after any stress test at 1.1v+ I would hit 99c after a few mins.
 I reseated the coldplate several times. 2 were just bad seats, with idle temps at 89c. The rest were good contacts but still no lower than 47c idle, so within margin of error.
 I recently read up on the solder issues with that line of intel cpus, and so Just got done delidding and applying Grizzly LM... and it dropped a whopping... 5c.
 Seriously, at this point I think I just got fked over by the silicon lottery. Might as well buy another cpu
 Is that a fair assessment?
https://linustechtips.com/topic/978859-terribad-temps-on-devils-canyon/
I have a TON of cooling success with that AIO.  My FX 8350 stays around 40-45c during 2 hour plus gaming sessions.  That's the only opinion I can give, that cooler is a beast and with Corsair Link...you should be able to keep that CPU cold with performance settings.  I run quiet settings and it just doesn't get hot.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
You can drop the voltage like crazy on a 4790k try a mild overclock of 4.5 on all cores and 1.25 volts or so, and try to get as low as possible with voltage until you're satisfied with temps.
Primary PC:
PSU tier list
How many watts do I need?
 I'm currently locked in at 1.183v, running stable at a fixed 4.4ghz.
 Still getting to throttle on Prime. Gaming and ther applications never go above 85c tho.
 If I ndervolt anymore it crashes under load :/
In that case, it almost sounds like something is wrong with the cooler, since at 1.18 volts temps should be excellent. I used a hyper 212 Evo to overclock my 4790k, so your extreme OC measures should deliver quite the thermal performance.
Primary PC:
PSU tier list
Exaclty what I thought.
 I reapplied Liquid Metal to the die, this time more generously. Same results. The delid is not the issue, it's something with the cooler or the chip itself is a garbage roll. Pump runs fine at 3000rpm. The fans also operate normally, and I can feel the pipes get prettt warm pretty quick.
 I'm thinking I may have bought a mini oven instead of a cpu...
  As a side note, Monster Hunter World seems to hit 95% usage commonly, and is the only game that gives me temps in the 80s and 90s. No throttling tho. Wonder why its so cpu-heavy.
 I must say I'm quite dissapointed with this processor. It' predecessor was a second gen i5 that hit almost 25% oc at sub 80c with less cooling...
Silicon lottery winners and losers, the sad reality
Primary PC:
PSU tier list
