Today when I turned my pc on, it took about 3 minutes to boot to the login screen, normally it takes 10 seconds or so. When i logged in, my mouse wasnt showing up so I had to replug it back in, my keyboard was also not working for about 10 seconds until it detected, my audio settings were also reset so microphone was set to 80% and auto voice gain was on. My speakers were also set as default instead of my headset.
I bought an external DVD drive yesterday which plugs in via usb and installed handbrake and the libdvdcss totally legal copyright remover but other than that i have made no changes.
Any help appreciated :)
Specs are
i7 4790k
Gigabyte 1080
12gb of corsair vengance ram @1600mhz
180gb boot drive ssd (intel 5 series)
1tb hdd
4tb hdd
1000w evga psu
CPU: i7 4790k
GPU: Gigabyte Windforce3 GTX 1080
RAM: 8GB Corsair Vengance 1600MHz (@1333Mhz) + 8GB Balisticx Sport or something 1333MHz
MOBO: MSI Z97 Gaming 5
PSU: 1000W EVGA 1000G 80+ GOLD
Case: Dark Base 700
Cooling: Dark Rock Pro 3 CPU Cooler + Standard Case Fans
Drives: Intel SSD5 180GB (Boot Drive) + Seagate Baracuda 1TB HDD + Seagate Baracuda 4TB HDD
Keyboard: Razer Blackwidow RGB 2013
Mouse: Corsair Harpoon RGB
Speakers: Creative T15 Bluetooth Speakers
Microphone: Samson Meteor Mic
Monitor: AOC G2590VXQ 75Hz + ASUS VS247 + Shitty Generic 1080p 60Hz TV
LED Controller: NZXT HUE+
https://linustechtips.com/topic/978349-long-boot-and-settings-revoked/
Have you attempted a reboot since this first happened to see if you can reproduce the same situation?
Some months back, (I apologize, I don't remember which build it was) audio settings functionally changed with a new Windows 10 build. Upon restarting after the install, I had a number of issues, including my mic volume being set to 0%, my default audio devices being reset and disabled devices being re-enabled, a longer-than-average load time as well as LGS failing to initialize until I rebooted.
On a totally unrelated note... holy PSU overkill batman ?
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
i reset everything to how they were before and restarted and it worked fine, just want to know what happened and if it will happen again
yeah i know, it was the same price as a 700w at the time so eh, why not
CPU: i7 4790k
Case: Dark Base 700
If there was a Windows update involved in the process of the shutdown prior to this, it may be the same issue I encountered.
So long as it doesn't continue to happen, I wouldn't worry about it, chalk it up to one of those technology-gremlin type deals.
alright, there wasnt any update but i did reinstall windows about a week ago, but if it was that then surely it would of happened earlier
CPU: i7 4790k
Case: Dark Base 700
@Semper it did it again this morning, settings didnt reset this time but it still took forever to boot and my mouse wouldnt work until i unplugged and replugged it
CPU: i7 4790k
Case: Dark Base 700
I'm not entirely sure why it would be a new issue, but my next recommendation would be to disable USB selective suspending.
Control Panel\Hardware and Sound\Power Options\Edit Plan Settings -> Changed advanced settings -> USB Selective suspend setting -> Disabled
I'm assuming the long load time is once you're past the UEFI/BIOS (if not, try flashing to the latest version, assuming you're not on it)? If so, it may also be worth trying startup repair and/or check the SMART of your boot drive.
alright, i'll give that a try tomorrow and see if it helps. i disabled booting from a cd drive in the bios since my pc doesnt have a disc drive anyway, also  unplugged the external one i bought. ive restarted a few times throughout the day but i will see if it is still doing it tomorrow morning since thats when both times the issue happened
CPU: i7 4790k
Case: Dark Base 700
well it was fine without the dvd drive connected over a few days but i put it back in last night and this morning it took ages to boot, guess ive found out why :/
CPU: i7 4790k
Case: Dark Base 700
