6pin and 8pin connection ???
Solved by Guest,
4 hours ago, Hi Guys Hope your well said:Do I need to upgrade ? Why is this ? I looked at the wattage of the 580 power colour and it’s 185w and recommends a 600w psu or are you talking about the amount of pins on the psu ?
you dont need to upgrade, people on this forum believe if its anything other than an evga 1000w gold rated psu its trash
as for your original question, your psu has two 6+2 pins on it, theyre 6 pins with a 2 pin thats detachable so you can use either as a 6 pin or 8 pin
