Hey everyone,
I was looking at getting some new headset and wondered what people would recommend. I am looking for a gaming headset with the best quality audio for gaming most importantly. My budget is around £140/$220 ish . My motherboard for connectivity and anything that you might need to know is a
M5A78L-M/USB3.
I don't want to get sound card.
I was looking at the astro a40 without mixamp. But was stuck whether or not i can connect it with either usb (and still have good audio) or the s/pdif port on the motherboard.
if you would like anymore info please write below.
p.s. comfort is quite important as well i dont want a painful head/ears after 30 mins.
https://linustechtips.com/topic/97810-headset-help/
I actually used that motherboard, about one and a half year ago, and although I was an entire noob, I did find the onboard on it to be.. not very good.. This mostly due to the way it distorted when I used the EQ in the settings on it, even the slightest change, it started crackling. Whenever I get my license back, I'm going home again where I have that motherboard lying around, so I can run a few tests of my own again,  but for now, I just want to tell you to get something like a FiiO E10. but I only want to tell you that, I'm not entirely sure about the onboard on that motherboard, I'm not directly telling you to get an E10. oh and btw, if you're outside of the US or maybe just outside NA, it might be a little overpriced.
oh, and I recommend you getting a pair of good headphones and a standalone mic, something like Sennheiser HD558 or Audio-Technica AD700X + a Zalman Clip mic or a Blue Snowflake. but if you absolutely want a headset, get the Sennheiser PC360, only gaming headset I'd recommend if you have the budget for it. oh, and if you want cheap headphones to go with the Zalman, either Superlux 681, or Pioneer SE-A1000.
Reviews: JBL J33i   M50s   SRH440   Soundmagic PL50
https://linustechtips.com/topic/97810-headset-help/#findComment-1308878
If you want headphones go for sennheisers 558s or m50s and a clip on mic but if you really want a headset go for the pc 360.
i7 4770k/Asus GTX 1080 TI/Asus RX5500 XT/Corsair Vengeance Pro 16GB/Samsung 840 Pro 256GB/Seagate Barracuda 3TB/AX860i/ASUS Z87 PRO/Fractal Design Define R4/HD 598
https://linustechtips.com/topic/97810-headset-help/#findComment-1318622
I use the PC360 and it's really good, much better for games than the PC350 SE because of the open design.
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/97810-headset-help/#findComment-1321097
