For which app?
If you are using Discord, then in the Discord settings visit the Keybinds page and assign an action for "Toggle Mute" and then input the keybind for it.
For OBS if you are streaming, then OBS settings, use the Hotkeys tab and assign a keybind for Mute and Unmute.
https://linustechtips.com/topic/977993-microphone/#findComment-11808070
15 hours ago, Spotty said:
For which app?
15 hours ago, karsnoordhuis said:
Discord has a push to mute function if you are using it. Some games support it too
No because sometimes i talk in game lets say on some multiplayer games like fortnite or battlefield
https://linustechtips.com/topic/977993-microphone/#findComment-11808072
In those games you will need to set the keybinding in the games settings for mute or unmute microphone.
You can also use Push-To-Talk so that your microphone is only activated when you are pressing the push-to-talk button.
https://linustechtips.com/topic/977993-microphone/#findComment-11808074
