Hey,  I was installing Windows 10 in my pc through a bootable pen drive. Everything was going on fine until my power supply just stopped and my PC crashed. I tried to open, but it is in a sort of mid-stage where it takes a lot of time to open and then shows me a blue error screen reading ":( There was some problem with your PC. We will try to restart it." and then it restarts and all this repeats in a loop each and every time.
    I tried to re-install Windows using my bootable pen drive. Everything opens, the installer and everything, but when it reaches the 'Select You Drive Screen' I cannot see my hard drive there. All I see is a drive with 0MB space used and 0MB space free and it shows an error asking for a driver. I tried using 'diskpart' commands in the emergency cmd, but they also can't recognize my hard drive. And yes, the BIOS does recognize my hard drive. I don't know what to do because my drive has pre-installed drivers, no CD or flash drive came m along with it, and I also tried searching for drivers over the web, but I can't find any. I also tried to search many other forums, but I couldn't find any working solution.
My hard drive is a 1TB 7200 rpm SATA drive.
Please Help!
https://linustechtips.com/topic/977937-hard-drive-not-recognized/
