Hey guys, so i've always had this problem with my pc. Whenever i'm playing a videogame it crashes after a few hours of gaming, overwatch, fortnite, etc..
The game freezes and then it closes with a crash-notification. when i'm playing fortnite it freezes and then the unreal engine 4 crash message pops out, same thing with overwatch but with another message saying "rendering device has been lost", i've also encountered some BSOD crashes, specifically the MEMORY_MANAGEMENT crash, this has been annoying me for over a year and I don't know a single way to fix it.
Also this crashes are happening constantly after I upgraded my GPU (which is a nvidia gtx 1050ti), and know it's starting to annoy me even more.
I don't have an excelent rig but here it goes:
CPU : Intel core I7-7700
GPU: Nvidia GTX 1050ti 4GB
Motherboard: BIOSTAR H110MGC
PSU: you probably don't know this brand, it's from the country where I reside    SPEEDMIND 800W GAMING PSU
RAM: 16 GB DDR4
Any help would be really appreciated!
https://linustechtips.com/topic/977494-videogames-keep-crashing/
so yeah thread solved? lol
you can check your temps if you want but sounds like the psu just hiccups and the gpu crashes as a result but not enough to crash the whole machine
doesn't even look like its 80+ anything at all
I'll try and change it, thanks for the reply!
