So i just upgraded my gpu from a 1050ti to a 1080 and i was noticing too much of a fps increase which was odd. I then opened msi afterburner to find that my 1080 was sitting at 35% usage while my cpu is form 98% to 100% and cannot nderstand why this happening. Any help would be greatly appreciated :)
System Specs:
i5 6500 @ 3.2GHz
8GB DDR4 @ 2133
Gtx 1080
rm 750x
https://linustechtips.com/topic/977141-can-someone-help-me/
it's either a bottleneck , or something about the game you are playing is loading the cpu too much for no reason
or some other program besides the game is using a significant chunk of the cpu while you are gamming , check task manager what does it say for usage as far as other programs go?
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800906
2 minutes ago, DanTheMan09 said:
@emosun So its a cpu bottleneck? if so what cpu would be good enough too handle it?
I7 6700 or better, some kind of i7 or an 8th gen i5 really.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800908
Not sure what MOBO you have, but a 7700K is probably the best option for you.  OC up to 4.8-5GHZ and it will improve your FPS.
You have 2 sticks of RAM, right?
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800909
i have a msi h110m gaming but can buy an overclockable motherboard if needed
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800925
4 minutes ago, DanTheMan09 said:
It happens no matter what game i play i get around 50% usage max on the gpu and 95-100% on the cpu
Desd giveaway for a bottleneck
Even without overclocking an i7 7700k will benefit a lot, but I recommend the non-k. Still a big jump.
Primary PC:
PSU tier list
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800929
Just now, TheGlenlivet said:
Don't.  Get a z370, or new z390 when they come out and buy a new CPU, if you have the money.
It's wasteful to just ditch the old parts, they're still good. Idk why so many people have a boner for coffee lake, you'd think it cured cancer. It's not worth the work of taking the motherboard out for 3 more FPS in my opinion, but I guess OP can decide.
Primary PC:
PSU tier list
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800937
So what would you recommend for my to buy that isnt a crazy price?
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800943
If he could OC on his current board I'd say keep it, but he can't.  And if he is going to buy a new one, Kaby and Coffee are technically better.
EDIT- read your last post first, see below.
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800944
THIS.  With an updated BIOS you can use the nonK.  This is the cheapest/easiest way.
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800949
I dont mind about the money as long as its not to the point of breaking my bank so an i7 8700k and what motherboard is overclockable and not overly flashy but somewhat cheap?
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800951
Well an 8700k and a z370 is about $500 for mid range  motherboard + CPU so if you can afford that you're good
Primary PC:
PSU tier list
https://linustechtips.com/topic/977141-can-someone-help-me/#findComment-11800954
