120mm fans help :/
What case are you using? Budget?
https://linustechtips.com/topic/976812-120mm-fans-help/#findComment-11797724
2 minutes ago, szym3k said:
NZXT H500, around £30.
Why not use the stock case fans?
https://linustechtips.com/topic/976812-120mm-fans-help/#findComment-11797739
Just now, szym3k said:
One of them broke :|
If you have proof of purchase for the case, you can probably contact NXZT for a replacement fan.
https://linustechtips.com/topic/976812-120mm-fans-help/#findComment-11797748
10 minutes ago, szym3k said:
Do you know how if they are any loud?
They're pretty quiet, I have 4 AF120s in my rig.
https://linustechtips.com/topic/976812-120mm-fans-help/#findComment-11797767
